RobS10 has it right. KDSS has no magical ability to reduce nose dive. In essence, it really is “just a sway bar,” but one that is hydraulically actuated. Like any sway bar, the KDSS sway bar works as a torsion spring to resist differential motion between each side of an axle’s suspension. It doesn’t do anything to resist equal motion of both sides, such as during hard braking — mechanically, it can’t. It doesn’t matter how much hydraulic pressure is applied to the piston, or whether the amount is different front to rear. When both sides move equally, all the sway bar can do is passively rotate around its long axis.
KDSS does not have less articulation than other T4R suspensions. If it has less overall travel, it’s only because of limitations imposed by the KDSS design, not because of any action the hydraulic system is taking.
2016 Trail Edition w/KDSS - Super White - Toytec - Eibach/Bilstein - Kumho 275/70-17
