I'm pulling apart my front hub / wheel bearing assembly, and want to know if this seal (90316-A0001) is installed from the inside of the hub, or from the inner / back side? I assume it's bad because I found a little spring behind the bearing assembly. Do I have to remove the drive shaft and install from the back side?
I tried uploading a photo, but it fails every time.
I'm confused because toyota dealer shows 90316-A0001 as the same part as 90316-72001, but looking these parts online, they look different.
