Originally Posted by mugenrios2k
There is the digram of the wire setup to make this work...
Reminder this setup requires that at least the parking lights to be switched to on
This is NOT FOG light on at any time.
To find the correct wires I used a test probe to find the +12V switched coming from the dimmer dial. ( blue doubled dashed line)
and the same probe to figure out the wire coming out of the ECU that is the power supply to the fog lights ( dashed red line)
Could you please tell me where "TO Original ECU Input" should I connect?
