Originally Posted by AuSeeker
Sounds like you've found a great T4R, although it's has about 60,000 miles left before a regular timing belt replacement, i would recommend considering replacing the timing belt as soon as you can because of the age factor, as mentioned with the tires rubber deteriorates with age and at 14 years old I would say it's at the end of it's life, but I could be wrong, no way to know for sure, but if it breaks the engine is toast, you should be able to get it replaced for under $1000.
So I just got the Toyota service report and the good news is the timing belt was just replaced in may. When should I replace it next? Every 70,000 miles? Also a big question I have is they didn’t replace the water pump. Should I do that right away? Or it’s not a huge thing to be concerned about?
