Originally Posted by MikeArnold
I cant post anywhere else so I am desperately looking for some assistance. I am a dumb a$s and was hauling 2x4s out the back window and backed up my drive way. The wood protruding from the window pressed up into the infotainment panel and the hazard light switch. My hazard lights are stuck on and the switch will not turn them off. Is there a way to bypass the hazards and still have functional turn signals?
I appreciate any help you all can provide.
Easy answer
No, the turn signals and flasher run through that switch. You can replace the switch but without it you won't have turn signals.
Detailed answer
With a schematic you can jumper pins to bypass the hazard switch but it will be easier to go to a junkyard and pull another hazard switch, or order one from your.local dealer/online
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Sport 4WD, V6 5-Speed e-Locker->
4WD 4runner Journal Thread
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->
2WD 4runner Journal Thread
