Originally Posted by Bombguy
Just an FYI, in most of the US it is illegal to run your high beams with your fog lights on while on public roadways. Not an issue if off-roading, but something to keep in mind.
Also if your state requires annual vehicle inspection, check lighting requirements. Most states do not allow more than 4 road legal lights to be on at same time. This why fogs turn off with high beams as when high beams are activated high and low beams, total of 4 lights, are illuminated on the 4runner. If they find you can turn on the fogs with high beams illuminated they can fail you.
And disabling the fogs just for inspection probably won’t fly either as typically all installed lights have to functional to pass inspection.
