I bought mine for 2100$. It was rough, and had leaks. Guy wanted 3500. I said no way with it puking oil like it was. I priced in the fact it needed work.
Sounds like you need to price it accordingly. You could relist it with some good photos, and a higher start price, so you can end up closer to your basement number. Or you can spend to do a timing belt job, and seal the valve cover leaks. Maybe you could splash on a cheap refresh paint job.
Thing is, those are all things I would do myself, including paint.
Another option is to donate the car to an organization that is setup for it, and you can take a tax credit for it. If the tax credit doesn’t help you then that’s irrelevant.
Good luck. Myself and my wife are both 5’11”. We fit just fine.
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
