The procedure is different whether 01/02 or 96-00.
Here's the '99 procedure:
And yes, if the master went dry, you'll have some extra work to do. See above. Also expect air bubbles in your ABS unit, which may be hard to bleed out.
Good luck - and next time, put a cap in/on the line when you open the system up...
'99 4Runner SR5 Auto -
4WD swapped
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
