Originally Posted by AdrianBrewster
I have a 99 so hopefully that makes it a little easier. I will say, only the back part of the reservoir is empty. The front is still pretty full. Which part of the reservoir runs to the ABS module? Fingers crossed it’s the part that still has some fluid in it.
The back part of the reservoir is dry and I’m leaving it dry until I finish my tundra brake upgrade so I don’t have to worry about the mess.
The problem is when you take off the master cylinder to bench bleed it, it will still have air in the lines. That air will get pushed into the ABS unit and then you'll have to bleed it out. You will know if you have air in the system if you bleed the brakes with the engine off, you'll hear either crackling noises in the line or a louder groan or creak. It should be whisper quiet.
