Long brake pedal travel
Brakes feel ok but they engage very low. Can’t lock up the tires. I have done the TBU, replaced the rear wheel cylinders, replaced master cylinder (helped a lot), upgraded to stainless steel braided lines, adjusted the e brake rear brake to come on at 2 clicks, power bled the system at 20 psi.
Any ideas?
EDIT: Added master cylinder to list of things i changed
Reason: Added master cyl to list of things replaced
