I believe you have ATRAC (electric brake booster assembly). My 2000 Landcruiser has the same ATRAC and the sticky paddle is somewhat common on LandCruisers. I installed another return spring and problem solved.
One of the possible issue is the seals inside the brake master pump sticking with the bore. If you want to fix it correctly, you will need to install the piston that comes with the seal. That will take a lot of time, (probably best to rebuild the ABS motor if removed) and bleed the brakes.
1990 3L Diesel Hilux LN 106; 1973 Ford Cortina XL
1992 4AFE Toyota Sprinter AE 91 (aka Geo Prizm)
1997 5vzfe 4Runner 4x4 (aka Hilux Surf)
2000 2uzfe 100 Series Land Cruiser
2021 Tacoma TRD Off-Road 4x4 6-speed
