Originally Posted by AuSeeker
If you're going to refill the system make sure you get a kit that has the oil with it, I'm sure you lost some of the oil that was in there.
I forget how much oil should be in the system, but I think it's about 1 1/2 ounce or so but I could be way off...do the research so you get it close to the correct amount, too little is not good and too much it also not good, but there's a little wiggle room in what is too much.
Yeah, I lost some oil, but not a ton. I'm guessing I just lost whatever was in the line for the most part. What I'm seeing online is most of the oil addition occurs when you change out one of the actual components instead of hoses.
My plan right now is to add a bit with the UV dye in it.
