Rattle sound from rear wheel area
Hello,
Asking for a friend
So I have a 2004 limited v8 4wd, no XRES. I also have a 2.5" lift and a magniflow exausht. I have a noise that I can only hear from the outside or with my windows down that sounds like something is loose in the area of my wheel. It only happens when I go over smaller bumps and it's a metallic rattle. I've tightened every bolt and replaced the sway bar bushings in the front and rear. I have no idea at this point and I'm curious if anyone else has had a similar noise or any advice as to what to check.
2008 4Runner V8 4WD Limited (Dobinsons 2.5 inch lift, JBA UCAs, 265/65r18 KO2s)
