and more fun: i've been pulling the #3 fuse under the hood often because it turns off the blazing stop lights. i forgot to put it back in this morning. started up the car, couldn't shift. the shift lock had activated. i pushed it down, and could shift. noticed for the first time the ABS light has turned on. i went under the hood and replaced the fuse. the ABS light stayed on all day. all other symptoms the same.
wondering if starting the car without that fuse in tripped the shift lock and ABS warning light.
as you can see, the #3 fuse is also swimming with many of the issues i'm encountering. thoughts?
