Originally Posted by UnderFire
I would start with the free stuff. Clean your MAF sensor, clean the grounds for the engine harness (one on coil pack bracket, one on intake manifold and one on back of head above exhaust manifold). Make sure you don't have any damage to the coil packs where the plug wires hook on, I've seen a couple burnt up from sloppy fitting plug wires.
I cleaned the MAF, TB and IAC about 18 months ago, so those should be fine, but I will take a look at the grounds and coil packs, thanks for suggestions!
You don't have any issues with hesitation below 3500RPM at WOT do you?
No, at WOT at any RPM is smooth.
