View Single Post
Old 07-19-2022, 03:01 PM
aemravan aemravan is offline
aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute
the spacer on this side is spacing the o2 sensor out too far and you're not picking up any readings to the sensor at partial throttle which is making the ECU think the sensor is faulty. What I did when I had a similar issue to bypass a failing cat is cut down the sensor spacer a bit to get the o2 sensor a bit more down into the exhaust stream until it started reading exhaust flow at lower throttle inputs.
2003 Limited V8 4runner - 37's, Tacoma Front End swap, ARB locked front and rear , LC200 rack swap
aemravan is offline   Reply With QuoteReply With Quote
