Originally Posted by Jakeepoo3
You can do it easily without a service port there are adapters for older vehicles. I never mentioned an electrical problem.. I recommended it as preventative maintenance before any issues ever occur. That kilmer guy is half retarded why you getting crazy on me luckers. Relax
The point you are missing is that a fuel injector has parts that will not be cleaned or helped in any way with fuel injector cleaner. The majority of fuel injector failures that we (the 3rd gen section) have experienced are due to the electrical side of the injector failing. Because there is no service port the fuel rails will need to be split and a fuel service port added in order to use that kit. Along with blocking the fuel return and disabling the fuel pump. It’s not a simple thing to do. If you have done it on a 3rd gen 4Runner then please enlighten us on how easy it is to do and what you did.
2000 SR5 V6 Manual 4WD
https://www.toyota-4runner.org/3rd-g...biography.html
