View Single Post
Old 08-08-2022, 04:08 AM
19963.4lsr5 19963.4lsr5 is online now
Next time it happens check for voltage on the small wire of the starter. It’s easy to simply do this with a test light. A volt meter if you got one.
If you have a bright bulb or 12v on the small wire the problem is in the starter or the feed to the starter has a bad connection somewhere.
No power on the small wire means a problem with the key switch, relay or P/N switch in the trans.
You could put a wire on the small wire of the starter and run it into the cabin and connect it to a light bulb, or read it with your meter so no help is required.
19963.4lsr5 is online now   Reply With QuoteReply With Quote
