Originally Posted by HamSnacks
2011 Limited
Driver's side isn't working, the little amber light does not come on. Checked the fuses, checked the plugs underneath the seat as best I could, just made sure nothing was unplugged.
Is it common for the actual switch to go bad? Don't want to buy a $120 switch and it turns out not to be the issue.
Any other things to check?
Passenger side works great.
Thanks
Swap the switch for the driver's side with the passenger's side. If the problem changes to the other side, it is the switch. If not, it could be the relay or wiring.
