Just thought I'd update this in case anyone in the future had the same problem.
So I pulled out the Driver's heated switch, unplugged it and then took it apart, it's fairly easy to pull apart, just need a flat head and have to run it along 1 side. I realized there was a little gold metal piece that was out of place, it sits on a plastic piece near the dial. I had to bend the board back a bit to make some room and then simply Krazy glued the metal piece where it was supposed to sit. Just like that, working again. If anyone ever runs into that problem and needs more detailed instructions, send me a PM.
Thank you
