Notices
View Single Post
Old 08-13-2022, 09:30 PM
ncflyer ncflyer is offline
ncflyer is on a distinguished road
FS: Cargo plate for 5th Gen. $55.00, NC
It's made from Baltic Burch, cut to fit over the front tiedowns and goes to edge of rear trim at rear hatch opening. I put a couple or so coats of spray liner top and bottom. In the pic, the circles are just imprint of round bases from a storage set up I had on it. No damage/indentions. The front (right side in pic) on the bottome is cut to sit on front tie down anchors so platform is flush/level with side molding.
Remove the rear tie-down points just behind the seats
Drill out holes in the rear so the OEM bolt holes could be accessed and put a couple holes in the foam for access.
Remove top carpet, lay this down and secure with front/rear bolts. It will come with hardware for front and rear.
No holes drilled as other rear plates but wouldn't be too hard to measure out and use some T nuts to secure whatever.
$55.00
FS: Cargo plate for 5th Gen.  .00, NC-rear-cargo-plate-jpg
ncflyer is offline   Reply With QuoteReply With Quote
