Originally Posted by hiluxsurf1
Thanks guys these answers are great, just what I’m looking for
The multimode system can be a little finicky sometimes. If you change between 2hi/4hi/4hi locked and the dash lights start flashing that means the system is trying to engage/disengage to whatever setting you are going for. Once the lights are solid you have achieved that setting.
I found that I had to be moving for the system to change settings. Sometimes steering back and forth left/right or coasting was necessary to change settings as well. It takes some experimenting to find what works best for your vehicle.
It’s also recommended to use the 4wd at least once per month to make sure it doesn’t seize.
2000 SR5 V6 Manual 4WD
https://www.toyota-4runner.org/3rd-g...biography.html
