Originally Posted by BabeGTR
Thanks for the advice. Update:
I read in a 4th gen discussion to check the battery terminals. My negative was loose, replaced it. AC went from blowing 60' at idle to now 40'. Apparently, the condenser fan is magnetic and needs that solid current. Also noticed engine temp (using an infrared thermometer) went from 208' to 188'. Could that have been burning the coolant too?
There is only one fan and it’s driven by a drive belt off the crank pulley. Infrared thermometer is not an accurate way of measuring the engine coolant temp. Best way is looking at the ecm data.
The ac system and the engine cooling system are two different systems. The only overlap between the two systems is the fan and fan clutch. The fan cools the condenser and the radiator. The engine coolant and the ac system never meet at any point.
Your heater core coolant flow valve could also be not closed all the way causing your ac to be warm.
2000 SR5 V6 Manual 4WD
https://www.toyota-4runner.org/3rd-g...biography.html
