View Single Post
Old 08-27-2022, 02:01 PM
VA_Runna VA_Runna is offline
VA_Runna is on a distinguished road
Originally Posted by flyrv9 View Post
I've changed 3 on my Tundra. Pretty easy if you have an O2 sensor socket. It has a cutout to accommodate the wires. Spraying a little penetrant makes removal easier. Make sure the replacement has the connector - some require you to splice the wires. I use a little anti-seize on the threads to make eventual removal easier. I have heard you can extend the life of your sensor by removing it and using a torch to heat the end and burn away the residue that may be causing the fault. I haven't tried this though. I have just used a code reader to erase the code and it works for a while. I have one now that's acting up. I erased the code a couple of months ago and it hasn't come back yet. However, I don't drive that much now being retired. As far as clearance goes - you might have to get creative and try a 6pt box wrench or something.
Thanks. Did do it completely from the bottom?
VA_Runna is offline   Reply With QuoteReply With Quote
