Crank no start no check engine light no tach bounce on crank
Engine ran > work was done > engine doesn’t run.
Seems pretty likely something wasn’t done right. A tooth could have gotten broken off the crank sprocket, or the cam sensor could be unplugged, or the timing was never set up right, or he also did valve covers and didnt reattach the plenum ground, just to name a couple easy options.
I also want to appreciate the irony: he’s a chemist, a smart guy. But he let’s a $10,000 vehicle sit for 2 years and gives it away. Hmmm….
I would figure this the hell out if I were you. That’s a gold mine.
