Originally Posted by brillo_76
If the Crank position sensor not working it will not throw the fuel pump relay on. No rpm. Dead engine on a 3rd gen v6 .
OK...but do you normally get a tach bounce when starting? That is my question (and a line of inquiry for the OP). Is the absence of a tach bounce on the 3rd gen an indication that there is a problem with the crank position sensor (or wiring/associated gizmos)? Somebody try this and confirm it.
