Real Name: brian
Real Name: brian
The hitch bend is nothing, that's minor, still usable.
The fender gap does look tight, maybe an aftermarket fender. See if there's a black sticker with the VIN number on it attached to the fender jamb in the engine compartment near the fender weatherstripping, If not it's aftermarket.
Hood looks a little wider than normal, still could be the aftermarket fender thing.
Frame and underbody look ok except for that bump on the rail above the resonator. Not sure if that's just a chunk ready to fall off or a bigger problem underneath.
Flare looks like it just needs some clips or the clip mount has broken off from the flare. Easy fix. It's held on by orange and blue clips( 2 different sizes ). If the mount is broken off it will need to be reglued. A good urethane or plastic bumper repair work well. Get some of the clips, they will break when taking the flare off. When they do get a pair of pliers and twist the clip 1/4 the way as they are not the same size on 2 of the 4 sides. Also, when taking the flare off there is a flare "pad " on the top edges of the flare, don't loose it you need it. There are also 3 rivets that have to be drilled out. Amazon has the clips in an assortment, good quality.
'08 4Runner Limited V8 Shadow Mica: Sport hood, bilstein 6112's, 5160's, b12 coils, Gibson cat back, 4runner XSP rims, Michelin X LT AS 275/55-20
'06 4Runner Limited V8 Salsa Red: bilstein 6112, 5160, Wheeler T12's, 4Runner XP wheels, Michelin AT2 275/55/20, Magnaflow Exhaust,, Powerstop brakes, sport hood
RIP.....'08 4Runner Limited V6: white, bilstein 6112s, 5160s, b12 , powerstop brakes, nav, TRD cat back, 4Runner XP rims, Michelin Defender LTX 275/55-20, sport hood
