Originally Posted by AuSeeker
Flared tubing and fittings seal between the female fitting/socket and the tubing, the male nut fitting is design only to apply pressure to the tubing so the female fitting/socket and tubing will seal to each other.
Makes sense, so either one of the male fittings I linked above are compatible with inverted/double flare? That is, either one will apply enough pressure to create that seal? I was definitely confused when I took another look at the OEM one and thought I purchased the wrong fitting.
