Originally Posted by AuSeeker
For a better seal than shrink tubing, get some rubber dip for tool handles, probably as close as you will get to the original coating.
Make sure the connections are not leaking before sealing them.
rubber dip for tool handles - Search
I've used plasti-dip in the past before, you'd need a few coats to have a thick layer, I did find some pretty thick shrink tubing that seems like it would work pretty well.
Wirefy 3/16" Heat Shrink Tubing - 3:1 Ratio - Adhesive Lined - Marine Grade Heat Shrink - Black - 50 Feet Roll: Amazon.com: Industrial & Scientific
