Speedometer malfunctioning, is it my speed sensor?
Hello Y'all,
I have a 93 4Runner, 2WD, AT, and the speedometer is not working, it doesnt move or is erratic. The transmission shifts normally and the car runs fine.
I assumed it had a speedometer cable but when I went looking I found two sensors, both on the driver side and at the back of the transmission. They look normal and nothing is broken.
I attached a picture of each sensor, one with a gear and one without. I also took a picture of the transmission label and the door label.
I'm not sure how troubleshoot the speedometer, I wonder if anyone can share the procedure to test the sensors and the part numbers for the sensors, I looked around the web and found conflicting information.
Thanks for the help.
