Originally Posted by fourwd1
The one with the gear would be for the speedo, the other I don't know offhand (temp maybe?).
The FSM would have procedures for checking both the sender and the gauge.
I think I can check the gear sensor by spinning the shaft while connected to a multimeter.
I think the other sensor is for the transmission ECU.
This morning, I brought the car up to temp, and I connected terminals TE1 and E1 at the diagnostic port and the "O/D off" and "check engine" lights starting flashing. I think the check engine is (41) point to the throttle position sensor and the OD is (62) pointing to a No1 solenoid. But I'm not sure.
Here is a video of the codes.
Thanks for the help.
