Originally Posted by message
I replaced my tank straps over the weekend and sheared off the bolts in the process despite my efforts to loosen them carefully.
I then used a punch and a large hammer to knock the sheared bolt and nut free inside the frame rail after reverse drill bits and easy outs failed.
As you can access the location via openings in the frame I used a magnetic pick up tool to align new hardware (fender washer + nylon nut + bolt) for the new strap.
I will be doing the same operation for all of the tank skid bolts I sheared off as well.
Mind showing pictures? You sheared off both of them?
