Originally Posted by AuSeeker
Ok, just wanted to know if it was one of the early model V6s that had head gasket problems from the factory, so since it's not a early model the question by
@ 5thToy
is hopefully a mute question..but if the new water pump and thermostat doesn't solve the coolant lost issue then you may want to do some checking into a possible head gasket being bad just to rule it out, i.e. checking the coolant for exhaust gases and as mentioned checking the oil for coolant.
Thanks, it occurred to me afterward I should have asked about exhaust gas as well. If If the system isn't leaking, it's either going through combustion cycle or getting in to oil.
