Originally Posted by blackmax
Stranded. So my 2003 4Runner V6 wont turn over. Put the key in the ignition on the lights come on everything is perfectly normal turn the key absolutely nothing happens nothing.
My 2 cents FWIW since these same exact symptoms happened to me recently. Turned the key and everything looked normal but crickets. OP said his battery was fine, maybe so. My truck would start with a jump but die immediately until I finally thought to give it some gas right at startup. That kept it running long enough to drive home. Long story short, alternator was bad and the battery tested so low that the dealer checked to be sure their tester was working right. New alt and battery fixed the problem.
