Originally Posted by ckisling
I’m mechanically inclined and have done done extensive stuff to this 4runner and my daughters that is the same year just the v6. I just don’t know what other tests to do or take it to another local mechanic? The mechanics it’s at now seem like they are price gouging and not wanting to see if it can be done without full engine replacement. Plus the car is 45 miles from me and they know that.
Buy a leak down tester that goes to around 100 psi and listen for where it's leaking. Soapy water also foams around a leak under pressure, although limited visibility here. Seems odd that 4 cylinders that aren't even next to each other would all fail, more common to have them fail next to each other and compression from one leaks through the open valve of the adjacent cylinder.
