It is a V8 Sport so Xres, yes. I cut and drained the lines up front when I installed the FJ struts. I did not remove the rest. Could that be a factor?
Originally Posted by jcaino
Assume its a base/sr5? otherwise, you would have xreas and would need to replace the rear shocks when you swapped for the fj ones.
sounds like your shocks f/r might be shot, also need to check the top mounts for the fronts and make sure they're not worn.
