Originally Posted by gookies
I plan on doing what you both did and just knocking out that weld nut, do you mind linking me to a similar punch you guys used? The ones I have now are smaller ones and would not work.
The Mayhew set sold at Home Depot is good quality and is (or was) made in the USA. You can also cut or drill hardened steel with carbide, I've only used it in die grinders but they do make carbide drill bits.
