Originally Posted by jbtvt
The Mayhew set sold at Home Depot is good quality and is (or was) made in the USA. You can also cut or drill hardened steel with carbide, I've only used it in die grinders but they do make carbide drill bits.
Yeah, drilling it out with a carbide bit was another option I had in mind, but knocking out the weld nut is probably the simplest now. I actually thought of buying a longer air hammer chisel bit instead, probably will be a lot easier than a punch with hammer given the awkward angle you'd have to hit at.
