Originally Posted by Zhehan
The reason I asked about cleaning the throttle body recently was it can cause issues like you're experiencing when debris fall into the IAC valve. This is a common problem when cleaning your TB. There are many threads about this issue. The high Idle you're experiencing now means you have debris in the IAC valve because you cleaned your TB. You're going to need to clean out the IAC valve to restore a normal idle speed.
The other symptoms you are experiencing related to the p0340 code are also symptomatic of IAC valve issues and throttle body issues. That's why we brought that subject up.
However, your main issue seems pretty specific to your Cam Position Sensor. The information you provided today I made that more apparent.
Having said that here is a thorough look at the p0340 code you are experiencing:
https://www.way.com/blog/p0340-error...shaft%20timing.
thanks for this, bookmarked.
the idle has actually come down to ~600 over a few days and seems to be holding. so far much more reliable. I plan on cleaning the entire intake from MAF to TB and IAC when I have time. (and replace fuel filter)
Originally Posted by RandyBobandy
That’s most likely your issue, get an oem sensor
if I need to I will.
Originally Posted by brillo_76
Also verify that wire harness to the cam sensor is good. Alot of times they deteriorate and need replaced as well...
ya didnt get a good look at this. i'll check when I go back in
Originally Posted by spartacus
Check the resistance is in spec.
saw this on the toolmans videos, everything checks out.
https://i.imgur.com/WQdryKXm.jpg
The Sequel - 1996 4Runner SR5 - Houston, TX
The Original - 2001 4runner SR5 - SOLD
Etsy Page - Custom Pinstriping and Sign Making
@8LinePinstripe: Instagram
