Originally Posted by MidwestJ
Have a brake light issue (lower driver side)
It’s not the bulbs
I’ve changed bulbs repeatedly (brand new bulbs) and I’ve got no brake light. I’m confident I have the bulb fully seated.
My passenger side is fine. Works properly. Top hatch middle brake light works properly.
I don’t need a new light assembly do I?
The rear driver’s reverse light works properly.
Is it the tan plastic housing that the bulb seats into that needs replaced? WTH do you even call that part?
I replaced the bulb just a few weeks ago and it worked fine. Now the bulb shows a black, burned spot.
Thanks.
If your model is 2013 or earlier then
Socket; Socket & Wire Sub-Assembly - Toyota (90075-60033
