I just replaced mine and the passenger side was seized. Driver's side was not. I cut the bolt with an angle grinder with a cutting disc. I used a ball joint press to push out the old bushings and also to install the new ones. I installed ES bushings which come with a new sleeve. I bought a new bolt for the passenger side.
2000 4Runner SR5 Manual Trans Federal Emissions - Eibach Pro-Truck coilovers, LC 7.5/Tokico Black, JBA UCA, SPC 25945 RLLs, Mevotech Supreme RULs, TrakMotive Xtended Travel CV Axles TO-8043ET, South Bend Rally Clutch, ES & Whiteline Bushings, MagnaFlow Cat-Back, Deck-Plate Mod, 4.56 Yukon Gears, Yukon Grizzly Rear Locker, Bushwacker Flares, 16x8 Wheels w/ 285/75 General Grabber AT2, 229K+ Miles
