Originally Posted by kolelt
Auto starter should work just fine. Also the cross member from auto should be fine. You’ll need a master cylinder line. eBay one for 93 Supra. Fits like a glove. I got it on mine. As far as wiring. You could trick the auto Ecu into neutral for mean time. But you’ll have check engine light. I don’t recall since it’s been long time. But 02 4runner should be plug and play with manual ecu. So I think a m/t ecu out of 2000 4runnee would be plug and play. I could be wrong. Again, been a while since something like this came up here.
Only a 2003 or 2004 tacoma will work because of the drive by wire. I personally did all my wiring at the auto tranny plug. I didn’t wire in the clutch defeat, but I did wire the cruise! You end up losing Traction control if you can’t live with the check engine light on the 2002 ECM. Personally I was glad to be done with it and installed tru-tracks. I’m in CA so I had to go this route!
