Originally Posted by EDC4rnr
Should be perfect. I had the T-13 with bilstein fj trail teams shocks. Gave alittle over 1” of lift rear and 1.75 front. You should also add one ome trim spacer on the driver rear if you have lean. Also, you might want to look into the bilstein b12 1” rear spring. It’s closest to factory spring rate.
Thanks, didn't even know about the B12. I'll go with the t13 and if it ends up being to tall, atleast I know the B12 is an option after that. Appreciate it!
