Map lights shorted??
Hello,
I am doing a LED upgrade to the interior lights. I was finally able to get one map done and was working. Then on the second one I broke the bulb, in my rush I just used my pliers to pull from the middle and I saw a spark...
Now neither map light works. The dome is still on, I thought they were on the same fuse?? The fuse that says dome is fine. Not sure if I shorted something out on the board or what...hope not!
Everything else on the overhead console is working. The little LED that turns on when you have your headlights on, all the crawl control settings.
Hoping someone may have some insight.
Thank you!
2018 TRD OR Magnetic Grey
So far all form and no function mods...
On the lookout for a PRO front valance...
