Real Name: N/A
Real Name: N/A
Like JZiggy said, these engines had problems with burnt valves. I've never heard of the valve spring issue.
I think I've viewed the video you linked a while ago (can't listen, at library), if I remember correctly they're referring to the burnt valve issue. And they recommend getting the valves adjusted, same thing you do to avoid burnt valve.
1998 4runner 2.7 manual
