Originally Posted by jbtvt
Wild. Never seen this on any gen although I did lose a threaded rear trailing arm on a '99 camry once 10-15 years ago. Poly bushings are usually stiffer than rubber and that one looks really tight in there, so the lack of flex is probably what did it. Also want to make sure your vehicle is at ride height when you install something like this, but even if it was, if things can't move the way they were designed to something is gonna give.
I agree the bushings seem to be the only area of difference from stock. I use the Stongflex polyurethane bushings that Sonoran Steel recommends. I'll be receiving the new arms Wednesday and I'll get some photos and see how tight they are. The additional concern this now brings up is that the same bushings are on my lower control arms
