Originally Posted by MidniteTRD
while those bushings probably allow for pretty drama free rotational movement (unless their bolt got REALLY torqued down tight), i wouldn't be surprised if those links sheared from binding in axial rotation (think of articulation, one wheel stuffed and the other at full droop). without a certain degree of give the only thing left to twist is the metal shaft itself.
i don't know the durometer of these bushings compared to other aftermarket choices, but its a problem that can rear its head in other applications, such as sports cars, where stock bushings with engineered-in-compliance are replaced with performance bushings that are too stiff, which then cause bind which gets worse the further through the travel range the suspension cycles.
really glad it failed in a mostly drama free fashion for you....that could have been a Code Brown for sure.
Great Post
Poly bushings are primarily for single axis use only.
Often the poly itself will split and crumble.
When more axis are involved a heim type joint is much better choice for a performance mod.
