Real Name: Ron
Real Name: Ron
There are aftermarket bushings available for all the control arms; front/rear, upper/lower, and ball joints for the LCA. Replacing them can be a PITA! I've rebushed LCA, bought a used SPC UCA with new bushings, rebushed rear control arms upper, lower and Panhard. The bushing aren't cheap, but less than replacement arms and you live in Arizona so rust shouldn't be a problem.
The LBJ on LCA were beyond me and the bushings would not come out, so I bought new 1Aauto LCA and rebushed them, those bushings came out pretty easy and the LCA came with new LBJ.
Close to $500+ in new Super Pro bushings for all, $400 for the LCA's, $300 for the used UCA and another $250 for new rear arms that I rebushed. So, however you decide to go it isn't cheap!
2003 Limited, V8, AWD. 4600 Bils/FJ springs, 1/2" spacer, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around.
