Originally Posted by Bmnorm2
The last poly bushings I installed required grease and even provided a small packet of said grease. I believe it was silicone based grease.
Do you know if grease is required here and was applied by installer?
They Stongflex bushings that are on there came with a packet of silicone grease. I didn't do the install, but I'll assume they used it.
