If anyone knows the part number for the bolts I would appreciate the help. The forward bolts are different than the rear bolts. When I look in the Toyota parts catalog this doesn't seem to be the case. It's possible the installer swapped out the bolts.
The only bolt part number I can find is 90119-14040
The nut I think is 90178-A0058
EDIT:
I think I need the following parts:
90119-14040 2each for mount to axle
90105-12340 2 each for mount to frame
90178-A0058 not sure about this, definitely 2 of these maybe
Thanks in advance
